MM Motorcycle
Karl in MD
02-23-2000 17:13:20
I have found a uni tractor. It's in bad condition, the front wheels are missing, the spark plugs are out, the radiator and carb are missing and the engine is stuck (it's a V-4). Is it worth restoring? Are these valuable? Would I be yelled at for converting it to something else? I have a 206 power unit. Could engine parts from it be used in the V-4? Thanks in advance.
Jeff in Md
02-24-2000 16:45:02
 Re: MM Motorcycle in reply to Karl in MD, 02-23-2000 17:13:20
FIX IT! It sounds like most of it is there and what is not there is probably available new or used.
Where are you at in Md
Karl in MD
02-24-2000 17:34:35
 Re: Re: MM Motorcycle in reply to Jeff in Md, 02-24-2000 16:45:02
Jeff:
Thanks for the input. I'm still trying to get up with the owner to buy it. I'm down in Somerset County, below Princess Anne. (Not exactly a hotbed of Moline activity, nearest dealer was 40 miles away) Where are you?
Karl
Karl in MD
02-24-2000 17:31:43
Jeff:
Karl
jeff in Md
02-24-2000 23:09:42
 Re: Re: Re: MM Motorcycle in reply to Karl in MD, 02-24-2000 17:31:43
I`am up in cecil county. What tractors do you have? Do you go to tractor pulls if you do maybe
you have seen my 5 star as I have pulled some
down on the shore.
glenn in md
02-25-2000 06:07:33
 Re: Re: Re: Re: MM Motorcycle in reply to jeff in Md, 02-24-2000 23:09:42
I'm glad to see someone else in Md that plays with MM's. I live in southern Frederick county in Tuscarora. I also pull Molines, a 50 G ,a 48 U, and a 55 GBD that I just finished, very anxious to pull it this summer It's HOT. I also use a G1355 to farm with. glenn
Karl in MD
02-25-2000 18:57:58
 Re: Re: Re: Re: Re: MM Motorcycle in reply to glenn in md, 02-25-2000 06:07:33
Hi guys; The only moline I have now is the 206 power unit on a skid. I did have an RTU, a 1940 model, which I sold some years ago up in Carroll County. I go to the pulls when I can, last one I was at was Goldsboro in the spring, a friend pulled my LA Case and his 830 Case (we didn't set the world on fire) If I get this UNI, I'll let you know. If I can't afford it, I'll post the location so somebody else can have a shot.
