UTS Brakes..HELP
jamieharrower24
01-02-2008 23:46:22
Im looking at a UTS for sale and it needs brakes. I have no idea about MM's and was wondering briefly what Im looking at to do the brakes on one.
Thanks
Jamie
molinegb
01-03-2008 05:37:49
 Re: UTS Brakes..HELP in reply to jamieharrower24, 01-02-2008 23:46:22
Depends what year the UTS is.U's had disc brakes beginning in mid 1952.
Bob M
01-03-2008 05:29:20
The UT's brakes are essentially the same drum car brakes - just much beefier. Any clutch/brake shop can can reline the shoes as LA suggests below. (I paid $50 to have my UTU brakes relined a couple years ago).
A few tips:
1 - You'll need a large socket (2-1/8"? - I'm not certain...) to remove the nut that secures brake the drum to the half shaft.
2 - If there's any evidence of oil leakage into the brakes, now is a good time to replace the brake drum seals. (Replacement is straight forward and seals are cheap)
3 - After repair, adjust the brakes EXACTLY per the manual (there's several steps involved). Otherwise the brakes may be ineffective and/or "grabby".
Good luck!
L . A. Lamb
01-03-2008 01:37:25
Not that hard to do. Thay unbolt off the tractor.
I had my UTU shoes relined at Ogburn's truck parts in Houston. ( cost was 58.50 in 11/06. Just
put everything back like it came off. I would get a manual if i were you frist tho. I sure helps..... ..L A
