Minneapolis Moline Tractors Discussion Forum
MM Z cluth adjustment
67
01-14-2008 18:38:35
I have a friend that has a MM model Z tractor. Could anyone be able to help me out on how to adjust the clutch? It is a 1957 with a hand clutch. any info would be greatly appreciated.
Gary from Muleshoe
01-15-2008 04:08:14
 Re: MM Z cluth adjustment in reply to 67, 01-14-2008 18:38:35
The Z were not in production after 1955. The ZB was the last to be produced and they had a foot clutch. You may want to check your serial number to find out the exact year model.
Cast Iron Dave
01-14-2008 18:44:14
A 1957? with a hand clutch. If it has a hand clutch, there is a inspection plate on the side of the bell housing. With the clutch disengaged, turn the clutch disc until you find a locking pin. You pull this locking pin out and turn the pressure plate until you get the desired snap of the hand clutch lever. Might need to spray the threads of the presure plate with penetrating oil first. Good luck.
67
01-14-2008 18:58:06
 Re: MM Z cluth adjustment in reply to Cast Iron Dave, 01-14-2008 18:44:14
Thanks for the reply. it will be very helpful. As far as I know it is a 57. Or so my freind told me.
