Minneapolis Moline Tractors Discussion Forum
What hyd oil in tel-o-flo?
Alan K
02-03-2008 16:04:56
I have an M670 Super and was wondering what is a good hyd oil to use? Ive heard hy-tran, AT fluid ( Dexron II )...any others?
Clint Youse MO
02-03-2008 17:17:23
 Re: What hyd oil in tel-o-flo? in reply to Alan K, 02-03-2008 16:04:56
We use the IH hytran and have had no problem I would recomend if you have more than one tractor you run the same in all of them because when you switch implements around the cylinders will retain oil and then mix the oils from the different tractors
schrocky
02-03-2008 16:39:35
Alan, the books call for Dexron II but I and many others I know have been using a quality Hy-tran in all our MM's with no problems .
KCTractors
02-03-2008 16:39:12
In my 602,I use universal hydro-trans oil.
