Minneapolis Moline Tractors Discussion Forum
MMM =RTU- questions
180doug
02-26-2008 05:20:17
I was wondering if engine parts overhaul kits are are avaliable for an RTU MM?Ive been looking on one and cant seem to find an overhaul kit;also Im new to MM [AC MAN] What size motor is in these ?I just inherited one thats needs going over; Thanks!
BMG1
02-26-2008 14:39:49
 Re: MMM =RTU- questions in reply to 180doug, 02-26-2008 05:20:17
Engine kits are not available for the R tractors. The engine is a model EE 3-5/8 x 4 which is 165 cubic inches. The EE engine uses domed or pop up type pistons. I'm not aware of an original or aftermarket source for these type pistons. Depending on how bad your engine is you can get rings, gasket sets, valves, bearings but you may have to get a little creative. For example, small block Chevy valves are very close in size to the original MM parts. Some used oversize pistons and NOS pistons kits can be found but they're getting very difficult to find.
Brian
R Moline
02-26-2008 18:50:31
 Re: MMM =RTU- questions in reply to BMG1, 02-26-2008 14:39:49
I have an almost complete R motor. It has a good crank and rods and good blocks and a good crankcase. I also have 2 other good blocks bored .040 over and 4 Z pistons on rods. I would sell any of it.
