Minneapolis Moline Tractors Discussion Forum
Jet Star 3 TSX 713 Marvel Schebler carb needed
b peppler
02-27-2008 04:28:56
Hello I have a 1964 JET Star 3 and the inlet part (cast iron 1/4"" part) of the carb has a crack in it. I epoxyed the area that was bad. It has worked but would like to get it right. The only time you have to much gas is when it is on FIRE! what other carbs/models would I be able to use. The one I have works great. I would only need the part that is cracked. Thank you. Brian
