Minneapolis Moline Tractors Discussion Forum
Need info or picture of M670 Super 3 pt pins
Alan K
02-28-2008 20:18:36
I need some measurements of the 4 pins that are on the ends of the 3pt ( allows the tilting to hookup implements ). The book lists one that is longer, and looks to have an extra hole in it. I cant find any and need to make some for mine. Does anyone have a picture of the pins or measurements where to drill holes and size of holes? Im guessing 302 670 G900 or G1000s would be the same. Thank you
matt in ind
03-01-2008 06:42:13
 Re: Need info or picture of M670 Super 3 pt pins in reply to Alan K, 02-28-2008 20:18:36
on my 670 super the pins are all the same at 3.25 inch x 1 inch..the holes are a shade over 1/4 dia. starting on one end shaped like a hitch pin type bevel 5/8 to the center first hole and 2 1/4 center of hole to center of second. with a small bevel on second end.. with that hole only being very close to that end. looks like a 1 inch hitch pin would make a perfect copy of mine.. they look factory.( no grind marks or anything?
