Minneapolis Moline Tractors Discussion Forum
MM Combine SP169?
1031D
03-03-2008 13:19:58
I have a chance to buy one of these. How big is the head? Are they reliable? Is there anything I should look at when I go to inspect it?
Roger - Kansas
03-04-2008 19:27:56
 Re: MM Combine SP169? in reply to 1031D, 03-03-2008 13:19:58
I am going to try to add a link to my SP 168. If it doesn't work the picture is in the tractor photos section.
My SP 168 has a 14 foot header. If I remember my sales literature correctly you could get a 12 foot head also. The serial number is on the Right hand side (standing at the back of the machine)about eye level near the end of the straw walker area.
Not much to check, just a simple old machine. More than likely the electric fuel pump just above the fuel tank will need to be replaced. Make sure the roller chain that operates the steering is tight and does not have any kinks. I am guessing this needs to be well lubricated. It looks to light to do the job and I have considered replacing mine with heavier chain.
When I was bringing this one home a man saw it and told me had run 2 of them years ago. He bought one new and it was under powered. The 3rd year he cut with it he decided to cut a hole in the exhaust manifold and add an other straight pipe. He claimed this made all the difference in the world. He bought the second one after it was traded in because it lacked power and he did the same thing to it. I have looked mine over and I think he is right.
I don't think I will modify mine. I only have 20 acres of wheat to cut. I have an Oliver 535, 431, 40, 2 - 35's plus this MM. I think the 6 of them can get it cut. However I might modify the exhaust if I decide to take all of them on the custom cutting run.
71ford100
03-03-2008 17:47:45
Do you mean 168? They are really hard to find so I wouldn't recommend as a combine to use but more of a collector combine. Where are you located.
1031D
03-04-2008 05:42:09
 Re: MM Combine SP169? in reply to 71ford100, 03-03-2008 17:47:45
I am in southern Wisconsin. I only plan on doing a couple acres of oats or wheat as a demo. A friend has the machine, it has not seen much use in the last 20 some years, but has ran 2006 oat harvest. I collect CASE, MM, and IH, and am a lover of the rarer things. He would keep it but the shed it is in is falling down so it has to go, and he was talking about cutting it up. It has a round grain tank and a continental? engine on top of the cylinder. The head has an auger in it. Where can I find the serial tag? What is it worth if it still runs good?
71ford100
03-04-2008 09:50:33
 Re: MM Combine SP169? in reply to 1031D, 03-04-2008 05:42:09
I see that you posted over on the combine board, Roger in Kansas has a 168 so he would be the best to talk to about actually using the machine, 1206SWMO may have a serial number list. 168's are rare so as far as value i really have no guesstimates.
