Minneapolis Moline Tractors Discussion Forum
M670 Ampli-Torque lever
Alan K
03-03-2008 21:15:26
The 1966 M670 Super I have has a "coupler" pipe on the lever about 6 to 8" up from where it starts the upward bend. It has two 5/16" bolts in it, one on each half. I thought they had just cut it off and put this on to splice it together again as they had a cab on the tractor. I ran across a picture of a late M670 super, 1969 or 1970 that looks like it has the same coupler in the same spot. Has anyone else seen these or did it serve a purpose Im missing? I was just going to replace the lever because I wanted it back to original.
Moline_guy
03-07-2008 19:17:52
 Re: M670 Ampli-Torque lever in reply to Alan K, 03-03-2008 21:15:26
third party image
third party image
third party image
third party image
third party image
third party image
third party image
third party image
third party image
I looked at dads vista today and forgot that when we had to pull the cab on it to work on the trans we cut the torque lever too and made the coupler like you talked about, looked at the 670 again and the more i look at it it probably was not a factory fix but just good machining by a shop. As far as the cabs i posted these pictures of the EXCEL cab on the m5, i think the 670 cab is MEADE but i don't remember anymore, 1030 case has the YEAR A ROUND cab and the oliver has a factory oliver cab but don't remember who made them either. The one on the 670 has aluminum window and after all the years of bouncing over hayfields they slop out and break in half, both dads and my vista have these chinsy type windows also. For a show tractor or one that is used lightly they would be fine. The excel cab has descent windows but like the 670 cab is kind of chinsy. The year around and the one on the oliver are nice solid cabs, and they don't vibrate. Someday when time and money allows i would like to mount a cab like my oliver has onto that 670 and then paint the cab gloss white or yellow, i think that would look sharp. The one on the oliver is similiar to some late model g1000's and 1050,1355 had on. I didn't have any pictures from the inside looking back, but there is just sheet metal that angles down by the seat, 3pt on 670 clears fine and one on M5 would clear a 3pt if it had it, not sure of the mounts will have to look, but i think they are just clamped around the axle and have a mounting plate above that. Have not seen any cabs around but i havent been out to any sales, we had a baby in January and it really puts a cramp into free time. Don't know how to use email, this computer stuff is fairly new to me, so until the wife shows me how to work more on this thing, i will stick to just the things i know how to do. One other note some of these pictures i just posted are about ten years old so these tractors have ten years of haying, feeding cattle, and general use added to them, but i had them in an album and they had the best view of the cab, also if you want to stiffen up the front end on the 670 we added another iron on the rear of the wishbone so the pin is not binding on one side, pin is supported from both side like the g1000 row crop fronts were, never had any trouble since we changed it. Hope you find a cab, i would give you mine but it keeps the sun and snow off my back. :)
Moline_guy
03-05-2008 20:10:22
third party image
My super is a 68 i think it has the coupler a few inches outside the transmission. Mine also has the cab and guessing that is why they put the coupler on to make the cab go on easier with less dismantling of the cab. My coupler is painted an off yellow along with the shaft where they must have cut it with a torch. Coupler looks well made so i am just guessing it was a dealer installed or made available to the dealers. None of our g1000's have the coupler even though they have cabs, so not sure why the 670 has it. If it was me i would just leave it but do as you wish, post some pictures if you get a chance. The more people that get interested in these MM's the less the iron man gets. Sorry my pictures aren't the best i use cheap cameras, then scan them, wife has a digital , but i am not sophisticated enough to get the photos onto the computer, take care.
Alan K
03-07-2008 15:16:29
 Re: M670 Ampli-Torque lever in reply to Moline_guy, 03-05-2008 20:10:22
I like the cab. Thanks for the info. I did wonder if that is what they did with them. What does yours have for mounts by the axle? I still have the mounts on mine. Can you send me any pictures of the inside of it? My email is open. Ive never been "in" one. How do they fit around the back like the 3pt and inside around the seat and hood?. I would still like to find one like you pictured for mine so if anyone has one they want to get rid of let me know.
