Minneapolis Moline Tractors Discussion Forum
Straightening front grille supports and hoods
Alan K
03-23-2008 23:34:32
Does anyone have a good way to straighten the front grille support on an M670 Super? The guy who had it before me had hit something up front and pushed back the cast front piece a little and the "removable" hood side panel doesnt "remove" that well as it rubs on the front and rear parts of the hood when I try to take it off. Any ideas?
T.R,K.
03-24-2008 17:42:32
 Re: Straightening front grille supports and hoods in reply to Alan K, 03-23-2008 23:34:32
Alan, I Don't have a 670super but I did some work on the front of my Jet3super. On mine mainly the mounting pads on the front supports were broken.
It sounds like to fix yours right you will have to take it-hood, cast front and supports- all apart and determine where it is bent, fix/straighten it and put it back.
You may have to remove the radiator too, especially if it uses the front bolster as the bottom tank like an M5. (It may be bent some as well.)
