Minneapolis Moline Tractors Discussion Forum
65 M670 steering
670dmm
04-03-2008 11:32:55
I have a 65 M670. I took the steering assist valve appart because i wanted to clean it and get steering both ways. I talked to a guy and he said they usualy only work one way. Now that I got it back together, it turns to the right on its own but won't turn back. I changed all o-rings, had to take some emory cloth to inside to clean carbon out,( had it in a ultra sonic cleaner and someone else put a piston in with it) so I don't know if i took off too much with the cloth. any suggestions?
670mm
04-05-2008 16:07:45
 Re: 65 M670 steering in reply to 670dmm, 04-03-2008 11:32:55
the tractor use to work by turing easy to the right but hard to the left when not moving. from what i was told that is normal for that system. After i took it appart something got messed up. I know it is in the valve its self.
Moline_guy
04-04-2008 21:44:57
I am sure this is not the problem because it steers one way but we had a spindle seizing up inside the tube, and for some reason it would steer one way but would squeel the steering belt the other way. We thought we had a failing pump or steering sector, until we figured out it was the spindle. We finally got the spindle freed up and greased and all is well. This was on a MM g1000.
Alan K
04-04-2008 21:23:43
Is the valve you cleaned the one that bolts on to the side of the steering unit? Not sure but possibly a bad O ring on the steering piston? Is the valve getting oil to both sides? Is it working any different that it did before you took it apart? I had rebuilt the one on my M5. They can be a fun one to get to work.
670dmm
04-04-2008 17:51:31
I have a IT, and a full 670 service book. i did not find how to correct it. I used it to try and fix it the first time.
Curt Cooke
04-03-2008 19:43:17
Invest in an IT manual for the 670 or borrow one from someone. It will tell you how to correct the problem with much more clarity than I can explain it. Good luck!
