Manure spreader ID/restoration
J.Groh
03-16-2000 21:16:47
I'm new to this board so I don't know if you talk about implements, but I hope you do. I searched the archives and found one post that may help but I thought I would ask all of you. I'm new to the MM world but want to do this spreader right. I am
restoring what I believe to be a Moline spreader. It has four wheels with rubber tires. The main
sprocket has "MOLINE" cast into it. The front axle housings have "MOLINE cast in a veritcal
direction. The rear tires are 20"X7.50. The spoked wheels have yellow paint hidden under old
grease. The framwork/axles were red. Absolutely no wood is left. If anyone could help me with
pictures, model ID, decals, if it had a seat or not (and what all of the wood looked like) I would
really appreciate the information. The framework which is made from angle iron bolted together will
be replaced. I would like to do justice to the rest of the spreader if at all possible. Thank you for your time and effort. Sincerely, John Groh
