Minneapolis Moline Tractors Discussion Forum
Light switch on M670 Super
Alan K
04-08-2008 17:04:11
I have a used light switch to put on my 1966 M670 Super. The place I got it from cut the wire resistor that is used for dimming the lights. Is there any way to "fix" it to use? Not sure if they are available anymore.
Alan K
04-09-2008 19:55:25
 Re: Light switch on M670 Super in reply to Alan K, 04-08-2008 17:04:11
Got my switch fixed. I used a resistor from an older M5 switch and pop riveted it on with steel rivets...and it even works. I dont know how much anyone ever used dim on tractors in the first place. Luke, did the switch you bought have a long coil of wire on it or a small resistor coil?
Luke Miller
04-10-2008 17:45:19
 Re: Light switch on M670 Super in reply to Alan K, 04-09-2008 19:55:25
It had a long wad of wire rubber banded to it that said resistor wire on it. It doesn't seem to dim down as much as my 670 does but it has a coil type resistor on it.
Alan K
04-10-2008 19:11:36
 Re: Light switch on M670 Super in reply to Luke Miller, 04-10-2008 17:45:19
Thanks for the info. Is that a special covered wire, or like regular wire? I have seen some used on stoves that is a special heat resistant wire, kind of cloth or fiber covered. Did you have to attach it or does it come attached.
Luke Miller
04-08-2008 19:58:55
The switch isstill available through AGCO. At least I got one for my 950 last summer. It had the resistor wire already on it. I can look through my reciept and try to find a number.
Alan K
04-08-2008 18:17:36
Also wondering about the power supply for the gauges as so far mine do not seem to light at all.
schrocky
04-09-2008 14:58:53
 Re: Light switch on M670 Super in reply to Alan K, 04-08-2008 18:17:36
Alan , an easy check for you is to put a hot wire on the B terminal, and then turn the switch into the first position and find which term. is hot, it should then stay hot in all positions. Did you get my e-mail about the parts ?
Alan K
04-09-2008 16:43:35
 Re: Light switch on M670 Super in reply to schrocky, 04-09-2008 14:58:53
No I didnt get it. Resend it if you can. Thanks.
