UT Exhaust heat Shield?
skycarp
04-26-2008 16:10:25
I am restoring a 1945 UT and am into the sheet metal right now. The hood paint is burned and the metal is distorted from the heat off the exhaust manifold.
third party image
Burned area
third party image
Distorted metal
I see this same situation on other U's that are farm ready.
Has anyone here been able to make a heat shield to take away the exhaust manifold heat before it collects under the hood and ruins the paint? Any suggestions would be appreciated.
skycarp
04-29-2008 19:36:38
 Re: UT Exhaust heat Shield? in reply to skycarp, 04-26-2008 16:10:25
Yes, there were bird nests in several places on this tractor. It was parked on a hill on a treeless farm for 8 years. I found many active wasp nests too. Likely could be the source of the heat damage.
Clint Youse MO
04-29-2008 17:00:22
see that straw behind the manifold very common to find a birds nest back there could be the start of the fire that ruined the paint on the original hood have this problem on our gas U's often and have learned to check the manifold and valve covers for birds nest
klw445
04-27-2008 18:28:11
Make sure you set the timing properly. Late timing makes it crank over easy, but you will definately develop too much heat in the exhaust.
Dale Hollen
04-27-2008 15:00:49
I have a UB that the hood was burned above the side panel. After repairing the hood I placed a piece of heat protective material (manifold gasket material) backed up with a piece of aluminum. I"ve pulled a 4 bottom plow many times and paint is still ok. Dale
Kevin Moschenrose
04-28-2008 22:11:20
 Re: UT Exhaust heat Shield? in reply to skycarp, 04-27-2008 12:47:39
Yes, That is the one.
Kevin Moschenrose
04-27-2008 06:48:01
If it has the older pot belly exhaust manifold on it you may want to think about switching it out with a new style Five star/ m5 style manifold. The pot bellys build up way too much heat in those. It won't be correct for the year of the tractor but will save on sheet metal and paint.
skycarp
04-27-2008 06:02:45
Well yes, it does look like fire damage to me too. The valve cover paint was burned similar so it could have had a fuel fire at some time.
I have the hood at a body shop now to see if they can shrink the metal distortion back to near normal.
Thanks for your perspectives.
wgm
04-26-2008 18:52:57
I'd say you have a major exhaust leak to cause this kind of damage. Usually it's just the side panel that gets burned.
Alan K
04-26-2008 20:34:32
 Re: UT Exhaust heat Shield? in reply to wgm, 04-26-2008 18:52:57
I agree with wgm. That almost looks like there was a fire under the hood to cause that much damage and distortion. Most of the time they burn through on the side panel because the hood touches the manifold directly.
