What extra accessories did the MM UTU (1949) have
Oliver662011
05-20-2008 18:59:58
I have a 1949 MM UTU, I am restoring, I am wondering what extra accessories you could get with it when you bought it. If I can find them I am going to fully load my UTU to show what all you could get. Thanks Mike
Oliver662011
05-25-2008 08:17:12
 Re: What extra accessories did the MM UTU (1949) have in reply to JK2, 05-20-2008 18:59:58
Nebraska K said: (quoted from post at 06:05:00 05/22/08) Dont forget the simple ones like the padded wheatland seat, and I think mabey a red tail-light.
Nebraska K
I would have to look into the seat thing to find out where to get one, but mine had a red tail-light already, i believe, I just went down to a salvage yard yesterday and picked up a new manifold, a belt pully gear box and pulley, and a pair of 80% tires. Mike
Nebraska K
05-21-2008 22:05:00
 Re: What extra accessories did the MM UTU (1949) have in reply to Oliver662011, 05-20-2008 18:59:58
Nebraska K
Oliver662011
05-21-2008 09:52:58
 Re: What extra accessories did the MM UTU (1949) have in reply to Ill John, 05-20-2008 18:59:58
Oliver662011 said: (quoted from post at 02:59:58 05/21/08) I have a 1949 MM UTU, I am restoring, I am wondering what extra accessories you could get with it when you bought it. If I can find them I am going to fully load my UTU to show what all you could get. Thanks Mike
Thanks Ya'll I will look in the parts manual I should have thought of that. :oops: Thanks Mike
Bob M
05-21-2008 11:56:43
 Re: What extra accessories did the MM UTU (1949) have in reply to Oliver662011, 05-21-2008 09:52:58
Mike - Curiously the parts manual that came with my '47 UTU shows neither the live hydraulics nor the cultivator lift. But my tractor apparently came from the factory with both installed. Go figure...(!)
deadeye012
05-21-2008 06:25:16
Let's see. Live PTO.. Belt pulley. Lift kit for cultivator. Extended drawbar. I would suggest that you get a parts manual. I think the accesories are listed in there....JB
Bob M
05-21-2008 06:19:09
Here's a few:
- Clutched belt pulley drive (standard belt pulley drive is constant running)
- Mechanical power lift
- Drawbar extension for above.
- Mounted toolbox (this may have been standard?)
- Live hydraulic pump, reservoir/control box and MM remote cylinder.
- Mounted implement lift mechanism for above.
molinegb
05-21-2008 04:43:59
Live PTO is one option that was available.
