MM Model 283E4, Serial Number 10901220
Charles R. Thom
04-18-2000 09:34:44
I have 2 Model H and 2 Model B John Deeres and a Farmall Cub. But now I have a MM. It is an LP model. The Model is 283E4 with a Serial Number 10901220. I am searching for a year of manuafacture and Model name. I will be needing a rear rim and tires at some point. The old tractor has a cab and the old tractor looks bad. The engine isn't frozen. Is there anyone that can help with more detailed identification?
Thanks, Charles R. Thompson
Quitman, Texas
lindsey
04-18-2000 19:10:23
 Re: MM Model 283E4, Serial Number 10901220 in reply to Charles R. Thompson, 04-18-2000 09:34:44
Based on the engine model and assuming the source listing was correct, you would have a 5 Star LP Minneapolis Moline. Be proud and treat it well.
larry
04-18-2000 15:04:39
The 283e4 number is the model number of the engine.I cant find the SN in the tractor SN,list. go look for a tag on the transmision.
