Hydraulics on a jetstar
kip weber
04-18-2000 13:21:11
On my jetstar I have dual hydraulics.The problem is that they don't stop cycling when you let go of the levers to the neutral position. Could any one tell me what's the problem and how to fix it?
Jack
05-30-2000 09:45:08
 Re: hydraulics on a jetstar in reply to kip weber, 04-18-2000 13:21:11
I need to repair a Jetstar III which has the identical problem. Has anyone else seen this problem and identified the cause? Thanks.
River Dale FarMMs
05-31-2000 06:10:58
 Re: Re: hydraulics on a jetstar in reply to Jack, 05-30-2000 09:45:08
The first I'd check are the lever return springs on each remote lever. If they are broke they will not neccassarily return to neutral. Gentle movement of the levers[1 at a time] should locate neutral. Replacement of broken springs is not a lot of fun but not real complicated. If both springs are good then the valves need to be recentered. Not a usual problem but we have seen this too. Takes more time and a lot of patience. Good Luck! Dale.
put put put
04-23-2000 17:29:28
I can't help you with your'e mini-mo but I'll give you a heck of a deal on a J.D. 70 completly overhauled with new paint.
