M-M----GTB-D
Charley
04-19-2000 15:31:26
Can someone tell me what the HP and the weight is on this tractor.....
Dan
06-16-2000 19:55:27
 Re: M-M----GTB-D in reply to Charley, 04-19-2000 15:31:26
the GTB-Diesel was the first of the Big diesels, it was a GTB gas tractor fitted with a six cylinder diesel engine. it has the same engine as the later GB Diesels except that the main and rod bearings are smaller, they are the same as in the 283 CI gas engines used in the Model "U", they just use one extra center main bearing. I have a GTB-diesel built in 1953. With 18.4 x 26 tires it weighs 7490, with 18 x 34 tires it weighs 7990. the diferance is the in the weight of the wheel centers. I also have a GB Diesel built in 1955, and there are some subtle differances in the two tractors.
larry
04-22-2000 05:58:01
I can only find the next newer model in this series. ITs a GBD its 65 hp and weighs 12500 lbs.as tested with balast the GTB is a little less hp. The older model GTA is 56hp.
