MM 283-4A Power unit
Ray
06-02-2000 21:13:59
This unit is used on an irrigation well. It has belts from a drive pulley from rear of engine and then to a well belt head.
I've got a head leaking compression into the radiator (foaming). I'm sure I have cracked head first guess and a blown head gasket as a second guess. Where can I get a good reconditioned head and gaskets? I'm not sure if both are bad or just one. It is running on a well here in dry south central Nebraska as I write. It is going to have to stay running till the heat comes on and then we'll have to do something. Anybody got a whole engine? Hope it hangs together for a couple more days at least.
Any help would be much appreciated, thanks.
Ray
billie
08-15-2003 12:42:37
 Re: MM 283-4A Power unit in reply to Ray, 06-02-2000 21:13:59
Hi Ray, We havea mm 283 4a and one half. We don't know the year of them but they have been setting for 20+ years. We have started working on the best one neither had an oil filter would you happen to know the size? It will turn over but haven't got it going yet.Any help would be nice.
Thank you,
Billie
Chickasha, Oklahoma
jeff
06-03-2000 17:04:16
Call Welters 417 498 6496
Ray
06-03-2000 22:30:32
 Re: Re: MM 283-4A Power unit in reply to jeff, 06-03-2000 17:04:16
Thanks everyone for your help. I've found a head, a new one at that.
Ray
HI SAM
06-17-2000 10:55:50
 Re: Re: Re: MM 283-4A Power unit in reply to Ray, 06-03-2000 22:30:32
DID YOU GET YOUR M-M POWER UNIT FIXED WHAT WAS THE PROBLEM? SAM DEAN TEXARKANA ARK.
