MM V or B.F. Avery V ?????
Mark Parker
08-10-2000 21:14:01
We just got this tractor and don't know which one it is. It has the ZXB-3 motor that the mm v has. But it has the Arched front axle like the avery v.
Unless some of the MM V had the arched front axle insted of a Tube front end. Where is the serial number suppose to be on them. what do the serial start with on them.
Jeff
08-11-2000 17:46:00
 Re: MM V or B.F. Avery V ????? in reply to Mark Parker, 08-10-2000 21:14:01
Go to minneapolismoline.com post your question attn. Tony Turner he will know
Loren Drake
01-16-2003 22:47:28
 Re: Re: MM V or B.F. Avery V ????? in reply to Jeff, 08-11-2000 17:46:00
I have a 1965 MM 705 diesel - good paint - good tires - above average. Just was wondering if there was any interest in this or if you could tell me where to look to put this for sale. Thanks Loren Drake
jim forsyth
08-17-2000 10:03:07
The serial # will be stamped into the top of the right side frame rail where the clutch housing mounts. It will start with a number like 7V. The 7 denotes the year.
