M-M 445
Tim Bragg
10-06-1998 17:23:11
I have come into a Minn-Moline 445 tractor model BLP(?) serial # 10200266.
Does anyone have or know where I could get some basic info on this machine,
such as year of manufacture, specifications, and parts availability? Also,
does anyone know how to bleed air from the power steering valve? I had to
replace the O ring seals in it, and it is working, but I can feel some air
in it as I try to turn it. Thanks a bunch.
Brian Rukes, The M-M Registry
10-13-1998 20:58:44
 Re: M-M 445 in reply to Tim Bragg, 10-06-1998 17:23:11
: I have come into a Minn-Moline 445 tractor model BLP(?) serial # 10200266.
: Does anyone have or know where I could get some basic info on this machine,
: such as year of manufacture, specifications, and parts availability? Also,
: does anyone know how to bleed air from the power steering valve? I had to
: replace the O ring seals in it, and it is working, but I can feel some air
: in it as I try to turn it. Thanks a bunch.
Your tractor is a 1956 model 445 (B1P) Utility.
They were made from 1956 through 1959, including serial numbers from #10200001 to #10202249. 1956 serial numbers ended with serial number 10201445.
Hope this helps.
Respectfully,
10-13-1998 20:58:02
Hope this helps.
Respectfully,
Dave
10-12-1998 20:05:10
Check with Panning Bros. Tractor Parts
Gibbon Minn. 800-635-0993 Fax 507-834-9713
They salvage a bunch of Molines
Dave
10-12-1998 18:16:33
I think it is probably a 1957. It has a 206 engine rated at approximately 45 H.P. parts are available from a variety of sources, look at Tony Turner's Unofficial Minneapolis Moline homepage and he has a whole list of parts suppliers. Also if you repeatedly turn the wheel from full left to full right, it should bleed the system (engine running).
Dave
10-12-1998 18:14:54
