Any other JetStar 2 owners out there
Chris
08-27-2000 21:51:38
I have a 1963 JetStar 2 Diesel , I want to know if any one has any photo's of this tractor , and if any one pulls with this tractor and if so how is it doing ?
Chris
charlie smith
07-15-2006 20:08:43
 Re: Any other JetStar 2 owners out there in reply to Chris, 08-27-2000 21:51:38
I have a gasoline version and it is hooked up to the bush hog and pulled out when ever it is needed. Runs like a top.
B.Lansink
08-28-2000 13:22:31
Hi there
We live in the Netherlands. Two years ago we imported a jetstar 2 Diesel from Canada. Our tractor has sn. 25700045. Ours has the heavy duty
style front axle, and 14,9 x 28 rears. As far we can tell it has all the factory options. Please let us know about your tractor.
Thanks!
Chris
08-28-2000 19:23:58
 Re: Re: Any other JetStar 2 owners out there in reply to B.Lansink, 08-28-2000 13:22:31
Hello back , My name is Chris I live in Virginia USA My
JetStar 2 has the heavy industrial wide front , 14.9/28 tires also, a very
heavy 3 point and draw bar , factory MM wheel weights , MM front loader with
down pressure , I don't have amplitorque but I do like the shuttle shift
instead . I found it in a field it had not run in about 12 years, I brought
it home and rebuilt the engine and it runs very nice. I believe that my wife
drives it more then I do. I will try to get photo's to send you. It needs to be repainted and I
have not put the hood back on yet ( just slow I guess).
Talk
soon : Chris
Matt Williams
09-06-2000 00:51:49
 Re: Re: Re: Any other JetStar 2 owners out there in reply to Chris, 08-28-2000 19:23:58
Greetings from Alaska,
I have a Jetstar 2 (gas) w/amplitorque that came with a farm I bought a few years back. I use it to tedder & rake hay and pull a bale wagon if needed. Runs great but I need to re-work the brakes and re-build the amplitorque when I get around to it.
TIM
09-12-2000 10:31:52
 Re: Re: Re: Re: Any other JetStar 2 owners out there in reply to Matt Williams, 09-06-2000 00:51:49
Hello,
My uncle has one in western Pennsylvania. It is the 15th gas one built. It was purchased by my grand father in 1969, as far as we know, he was the second owner. The amplitorque and brakes need work but it is still used daily on his 70 acre farm. Strong as ever.
Tim
