M670 LP convertor problems
B,Lansink
08-28-2000 13:35:27
We own a M 670 LP tractor that is fitted with an Ensign LP system. We just had it running, but we don't know how we should fill the tank, as we live in the Netherlands. How high should the primary pressure towards the convertor be?
Can we use normal LPG from the gasstation?
Hope someone can help us.
Thanks!
propane
08-28-2000 20:38:14
 Re: M670 LP convertor problems in reply to B,Lansink, 08-28-2000 13:35:27
150 psi give or take 10 psi.
LP is propane, I run home heating propane in mine.
Tank should have liquid and vapor valves on it. You will need to start on vapor in cold winter time, below 30 degrees (F). Run on liquid after engine is warmed up, thermostat open. Good luck
