1949 ZAU cylinder compression
Roger
09-27-2000 04:11:18
Recently acquired a 1949 ZAU, it runs and sounds good. The compression on each cylinder is 80 pounds. What should the compression be? Also whenever I attempt to take off in 5th gear the engine pulls down and does not recover. All other gears seem to be normal. I have rebuilt the carb, and tuned it up and nothing seems to help. Would appreciate any suggestions.
philo
09-27-2000 13:00:59
 Re: 1949 ZAU cylinder compression in reply to Roger, 09-27-2000 04:11:18
Check to see if your governor is reacting. If the governor is worn and not working properly the engine will fall flat on it's face under pull. As for compression I am wondering the same thing on my R.
philo
Oldtractor
09-27-2000 19:09:02
 Re: Re: 1949 ZAU cylinder compression in reply to philo, 09-27-2000 13:00:59
80 would sound a little low, 100 to 110 would be my guess.
