3 Point Hitch
Kenneth Biggs
10-18-2000 16:30:57
Help! Just bought MM 335 Model Utility , I think 35 HP, Serial# 10401181 (1957) production, The hydraulic lift won't work, The previous owner showed me it was working ( it was not under load), It has three levers ,one is to raise the lifting arms, I have replaced hyd. oil filter and added hyd.oil ,through the inspection plate on top of the chamber ,there does not appear to be a specific "add oil" inlet, Don't know if the system needs to be bled, There is no resistence when lifting the arms manually, Can someone advise on the operation of using the 3 point lift Thanks , Ken Biggs
