I have two MM M5's. Both are Diesel. One is early 1960, the other a 1962. I strongly believe they are a great tractor for most middle applications. Things I suggest you consider are the following; 1. Early diesel models have the American Bosch Fuel injection system...generally more expensive to repair...later models have the Roosa Master system, cheaper and more readily repairable. 2. Diesel is great, but hard to start in the winter...definately have to pre-heat and use ether. Need good batteries with lots of cranking power. 3. Amplitorc low range should not be used in cold conditions, or in downhill runs. 4. Parts are a bit difficult to come by...one of your other correspondents mentioned Welters Farm Supply. I have used them, and they are great. Best prices and very helpfull. Very few of these tractors in wrecking yards...those that are seem to be there for a reason. 5. If you decide to purchase an M5, I have all the operator's, maintenance and parts manuals. I can make you a copy for a nominal fee. Good luck with your purchase! Ralph
