Head bolts are torqued to 50-55ft. lbs. The bolts that hold the blocks to the case do not have a torque specified. I would suggest that you torque them to 15ft. lbs. They just hold the blocks too the case and there is only a thing cork gasket that you sealing against. One thing - if you go to change the head gasket - you have to loosen the bolts that hold the blocks down to the case. Tighten the head bolts in a stage of 3 - like 20ft.lbs., then 35ft. lbs. then final torque. also, you need to go from the center outward in torquing the thing. After you have run the tractor and had it hot - and it has cooled - go back and retorque it. As for your oil leak - not sure what you are referring too. However - if it is a seeping crack in the casting and not leaking under pressure - a little "JB Weld" or other metal putty would probably stop it.
Remember - the "head" is on the left with the spark plugs in it. The "blocks" have the valves and make up the cylinder bores, the "case" is where the crankshaft is. This little engines are a little non-traditional in design. If you are leaking between the blocks - then you probably have a bad block base gasket - and the only way to fix that is to pull the blocks off the tractor - this involves removing the rod bearings and a whole bunch of other work that you may not want to get into at this time. My suggestion to you is to seal that crack - if th oil is coming from there as I advised - Get ya a can of starting fluid - ether - and spray down the area to get all of the oil residue off. (the ethere evaporates and leaves no residues) Then you can paint it and be on your way. If you can live with the leak - then wait until you have some major repair work to do before you go and tear into it. Phil
