MM U302 has no high range??
Rod
10-30-2000 09:48:15
I have a MM U302 with loader that has always run well and is used to handle round bales.
This past weekend when I engage the ampli-torc, nothing happens- it continues to travel at the same speed.(with or without a load)
I believe the ampli torc does need to be adjusted slightly as it engages quite easily but I don't think this is the problem. Does anyone have an idea of what the problem could be? Also where can a good supply of parts be found?
Thanks
Jeff
10-30-2000 16:57:55
 Re: MM U302 has no high range?? in reply to Rod, 10-30-2000 09:48:15
Clutch dics in torq have small "ears" They are most likely broke off. I would try to adjust it first. Call welters 417 498 6496
