602 hyd.
Maurice Phelps
11-12-2000 06:50:39
I have a 602 that has a hyd. system that is not covered in the repair manual. It has 2 levers for the remotes, 1 lever for the 3point,under the seat there is a lever that moves a cam follower that followes a cam on the 3point rock shaft. Anybody have any info on how this system works.
Peter Deur
11-13-2000 11:01:03
 Re: 602 hyd. in reply to Maurice Phelps, 11-12-2000 06:50:39
Hellow,If the levers are under the seat they are for rate and cycle of the 3pt hitch. On the Minneapolis-Moline homepage there is a book listed for hyd systems. Hope this helps.
Mike
11-12-2000 16:07:23
I just bought a 602 back in the summer so
I bought a service manual and I wonder if your talking about the two levers on top
of your hyd. unit under the seat. If so
the one on the left side(if your sitting
on the tractor) is the rate lever and the
right one is the cycle lever.
