335MM
Jarrod
10-20-1998 18:41:31
Where do you check rearend oil on a 335 Minnie? Is there any way to adjust the torque amplifier? Seems to slip either at the engine clutch or the torque amplifier. Wanting to sell. What is it worth? Runs okay, decent rubber, kind of tired. 3-point and pto.
Harrold Rhodes
10-29-1998 18:28:48
 Re: 335MM in reply to Jarrod, 10-20-1998 18:41:31
: Where do you check rearend oil on a 335 Minnie? Is there any way to adjust the torque amplifier? Seems to slip either at the engine clutch or the torque amplifier. Wanting to sell. What is it worth? Runs okay, decent rubber, kind of tired. 3-point and pto. There are two pipe plugs on right side of tranny case. With engine running and TA in high range oil should run out the lower one. TA can be adjusted through hole in right hand side of tranny case. What fuel is your 335? Where ARE YOU LOCATED AND HOW MUCH WANT FOR
for it?
Jarrod
11-19-1998 17:27:37
 Re: Re: 335MM in reply to Harrold Rhodes, 10-29-1998 18:28:48
Harold, The 335 that I'm talking about is my dads. It is a gasoline tractor. I looked for those small plugs to check the oil and found one small one on the right side. It appers to be in the right place for an oil level check. However I did not find any place to adjust the ta. How big of plug or hole or what am I looking for to adjust it? I don't know what he want's for it. He's looking for a 930 case and when he finds one then he'll be ready to sell. I'll let you know. If there's any more information you can give me I would greatly appreciate it. Sorry it took so long to respond back to you. Did you think I fell off the earth?
