G-1000 Vista PTO
Floyd Schmall
12-04-2000 19:55:33
I have a G-1000 Vista and I need to adjust or overhaul the power take off. Is it possible to remove the deck without removing the cab or can I just remove the fuel tank? I am Also looking for a battery box cover for the large 12 volt style box. Also the panels that fit behind the head lights on the fenders 10a22489 part number and a original amp gauge. THANK YOU! Happy Holidays.
Motec Engineering
12-05-2000 09:10:12
 Re: G-1000 Vista PTO in reply to Floyd Schmall, 12-04-2000 19:55:33
We have the fender panels that you need. They are $10.00 each (includes shipping).
Email us your address for a free catolog.
Motec Engineering
7342 W State Road 28
Tipton, IN 46072
762-963-6628
MotecEngr@aol.com
KS
12-04-2000 20:48:35
It depends on what you need to do. If memory serves me the PTO clutch is on the bottom of the tractor, but the PTO brake is on the top. If you're draining the rearend to adjust one you may want to do both. If your problem deals with the shaft or final gear, that is accessible from the rear. The I&T manual documents it very well.
