Head gasket on MM 335
Jim H.
12-05-2000 05:17:00
Hi folks,
I went to look at my father-in-law's tractor last night. He was going good the day before and then suddenly lost power, black smoke from the stack. Plugs 1 and 2 from the front were black and wet, 3 and 4 were lighty covered but still looking ok. Cleaned and gapped all, checked for spark on 1 and 2 (spark ok)checked other wires, and reassembled w/ plugs in no particular order. Started, no changes in sound or smoke. Pulled plug 1, wet. I had these symptoms on a pick-up and it was head gasket.
Does that sound right?
Thanks for any help. We are looking for a ballpark time estimate for a couple of intermediate level mechanics and sources for parts in SE Minnesota. We have the operators' manual and a shop manual (ITT I think) as well.
Jim
Dirttracker
12-07-2000 16:32:11
 Re: head gasket on MM 335 in reply to Jim H., 12-05-2000 05:17:00
Pull the plugs and run a compression check on all cylinders. A blown head gasket will show up. Is it blowing any coolant out or getting coolant in the oil? Your tractor will more often blow to water than to the next cylinder. If the compression is ok make sure the points havent closed up and that the fuel system isn't flooding or the air filter plugged. They need cleaned from time to time.
I have seen air filters so plugged that the engine ran so rich that it smoked badly and missed out on a cylinder. Its more fun to only repair it once. Have fun.
Jim H.
12-08-2000 06:23:04
 Re: Re: head gasket on MM 335 in reply to Dirttracker, 12-07-2000 16:32:11
Thanks for the tips. A mechanic-buddy of his came out and did a compression check. All were perfect. He did a parts and wire replacement of the ignition circuit, cap, rotor, wires, etc. He (my father in law) can still sees smoke and ins't quite convinced all is well. I'll have him check the air filter. I had a similar thing happen to my Oilver 88 diesel snowplowing in the snow. It started running horribly. Went by the air filter intake and heard a hissing sound. I pulled off the lid of the filter and the tractor gained several hundred rpm. It had iced up.
Jim
Peter
12-08-2000 17:14:01
 Re: Re: Re: head gasket on MM 335 in reply to Jim H., 12-08-2000 06:23:04
A couple of other things to check. The air cleaner is a oil bath type for that model and when you take the bottom oil bowl off get a stick or screwdriver and put a rag on it and poke it up the center tube . I have seen a lot of tractors with clean oil bowls but the tube was parshaly pluged. While cleaning the air system check the air intake in the hood to make sure it is open. Also what brand of spark plugs are you useing? In the last few years I havent been able to keep Champion plugs to last long. I have had much better luck with Autolite or AC. If you do not have electronic ignition use copper core spark plug wire it will work better that carbon fiber wire.
