M602- PTO?
JRZEPKA
10-21-1998 09:40:52
BOUGHT A M602 GAS WF FOR WHAT I HOPE WAS A GOOD
DEAL. BUT THE PTO ALWAYS RUNS. WITH TRACTOR OFF YOU CAN SPIN IT FREE WITH PTO CLUTCH DISENGAED
AND IT IS LOCKED WHEN YOU ENGAGE THE PTO CLUTCH.
WITH THE ENGINE RUNNING YOU CANNOT STOP IT ? EASY TO FIX ON NOT?
ALSO WHAT OIL DO YOU RUN IN THE HYDRALIC SYSTEM
BOOK SAYS MM SPEC # ..... ... WHATS THAT IN TODAYS TERMS
UNIVERSAL HYDRALIC? STRAIGHT 30 LIKE MY OLIVER?
ITS A TEL-E-FLO . THANX IN ADVANCE JEFF
Dave
10-21-1998 20:01:47
 Re: M602- PTO? in reply to JRZEPKA, 10-21-1998 09:40:52
: BOUGHT A M602 GAS WF FOR WHAT I HOPE WAS A GOOD
: DEAL. BUT THE PTO ALWAYS RUNS. WITH TRACTOR OFF : YOU CAN SPIN IT FREE WITH PTO CLUTCH DISENGAED
: AND IT IS LOCKED WHEN YOU ENGAGE THE PTO CLUTCH.
: WITH THE ENGINE RUNNING YOU CANNOT STOP IT ? EASY TO FIX ON NOT?
: ALSO WHAT OIL DO YOU RUN IN THE HYDRALIC SYSTEM
: BOOK SAYS MM SPEC # ..... ... WHATS THAT IN TODAYS TERMS
: UNIVERSAL HYDRALIC? STRAIGHT 30 LIKE MY OLIVER?
: ITS A TEL-E-FLO . THANX IN ADVANCE
: JEFF
That was a nasty trait of the Molines for the PTO to keep on running like yours. The later tractors like the late ser.# M670's added a PTO brake to help stop PTO run-on but it was a puny little band & didn't last very long. I would run universal hydraulic fluid in your system.
