LP GB
Rick
12-17-2000 14:26:40
I have a LP GB Moline that runs good, but must run with choke on, any one have any idea.
LP is new to me, all my tractors have been gas. Thanks For your help.
Harrold Rhodes
12-24-2000 16:11:40
 Re: LP GB in reply to Rick , 12-17-2000 14:26:40
If it still has its original Ensign carberator The economizer which is also the load adjustment on the side of carb connected to a vacum line may need adjusting. Disconnect vacum line and turn this unit to the left which makes it richer. It could be a lot of things this would be first I would check.
galen
12-17-2000 20:26:54
could be several things. Start with making sure you haven't got a plugged fuel filter not sure if GB had one later models did. Make sure yourfuel valves are openig all the way. From there you go to checking regulator and carb. Not much different than gas tractor just have to adjust for the fuel type and becareful as lp can freeze you real quick.
Joe Leising
12-17-2000 18:56:13
Rick don't know much myself except that you must start them on vapor only until they are completely warmed up other wise the fuel doesn't mix right
joe
Rick
12-24-2000 17:47:12
 Re: Re: LP GB in reply to Joe Leising, 12-17-2000 18:56:13
Thanks for your help guys.
