GVI
Ron Guckenberge
12-30-2000 18:51:41
Can anyone tell me if a MM GVI (diesel) is a good machine? Also, one in average condition with a cab is worth????
thanks
Tom Railsback
12-31-2000 15:54:47
 Re: GVI in reply to Ron Guckenberger, 12-30-2000 18:51:41
In June 1971, my dad bought a used GVI to replace
a 20 year old La Case. It was basically a good
tractor with only one problem; it ate water pumps.
In the two years we had it, we replaced the water pump three times. Finally, we found out that the
problem was that the pump drove from a machined hole in the timing gear and that hole was worn
enough to throw the pump out of line. We replaced
the gear and that solved the problem. My only
other complaint was that the clutch was real
jumpy and you could hardly ease the tractor back by inches when hooking up to your implement.
Other than those two things, it was a pretty good
tractor.
As for value, I have no idea what one would be worth these days.
Dennis Flanery
02-22-2001 16:17:03
 Re: Re: GVI in reply to Tom Railsback, 12-31-2000 15:54:47
can anyone tell me if a 1961 GVI Diesel has live power or can it be added to a tractor without live power?????
