Avery identification
roy mack
01-14-2001 20:55:43
Any way to i.d. avery tractor without frame rail tag? Cant seem to find frame rail tag and am not sure of this model, was told it was a 39 but as it has a coil and dist. I wouldnt think it was that early. I need a clutch disc, throw out bearing and pressure plate top make it go and cant get it until i find out what year it is. any help would be greatly app. Thanks, Roy.
Jack Horner
01-18-2001 15:43:58
 Re: avery identification in reply to roy mack, 01-14-2001 20:55:43
Roy, On the Avery "R" and "A", the serial number is stamped directly into the RH Rail, just next to the shifter. My MM BF has the serial number R3648 just next to the shifter.
Jack
BMG
01-15-2001 19:43:36
Roy, Avery did not have tags on the frame. They stamped the serial number directly into the frame rail. On a model V its on the RH rail near the bell housing on the top side of the rail. I'm not sure but I think model R or MM BF's etc are somewhere near the rear end housing still on the frame rail. Hope this helps. Brian
