335 moline with 6volt electrical system want to convert to12v
Wyatt W.
10-30-1998 21:16:10
We have 335 MM with a 4cyl gas engine that is 6 volt we are looking for what 12v parts we will need any help appreciated.
Harrold Rhodes
11-04-1998 19:12:44
 Re: 335 moline with 6volt electrical system want to convert to12v in reply to Wyatt W., 10-30-1998 21:16:10
: We have 335 MM with a 4cyl gas engine that is 6 volt we are looking for what 12v parts we will need any help appreciated.
First thing is a 12 volt condenser or resistor to cut ign back to 6. I prefer 12 v condenser. Starter shoud be ok as is. If you 12 V Ignition you will need change coil to 12 V. If generator is good you can set the regulator to charge the 12V battery and you should be OK.
