U302 Super Help!!
Alex
02-09-2001 13:17:41
I need some help Minneapolis - Moline experts!
Two questions?
1) I am about to replace the clutch pilot bearing . Should I pack the are behind the seal with grease or just smear some grease on the seal?
2) Is it possible that my U302 never had the wire that holds the water pump bearing in place? I have cleaned and looked several times and cannot find a hole in the casting for it.
Thanks in advance for your thoughs and sugesstions.
Alex
Alex
02-12-2001 17:17:32
 Re: U302 Super Help!! in reply to Alex, 02-09-2001 13:17:41
Thanks for the help -- found the hole and groove in the water pump.
Peter
02-12-2001 13:52:08
The water pump bearing is held in place by a wire that is slid in the small hole in the side of the casting. The bearing assembly also has a grove in it for this wire. The old wire may have rusted away or if the pump has ever been repaired it may have been left out.
galen
02-09-2001 16:57:24
The pilot bearing on most tractors are sealed bearing. Putting grease behind it doesn't help the bearing any at all. As far as the water pump there should be a snap ring that holds the bearing in place probably on the radiator side of the pump.
