MS Carbs On Molines
I Redman
02-17-2001 20:30:09
Can anybody tell me what the difference between a MS Tsx-67 and a MS Tsx-693 carb is????? ? Please I need some serious help!!!! I have exhausted all me resources and nobody can tell me. Somebody has to know! Thanks I.R.
kelvin
02-21-2001 12:30:24
 Re: MS Carbs On Molines in reply to I Redman, 02-17-2001 20:30:09
Guys, here's the differences you are looking for:
throttle shaft-same/different? on same side carb?
throttle plate angle-(usually stamped on plate)
fuel inlet which side?-the casting will accept both.
metering valve (more than one?)
main needle?
main jet
main nozzle
idle jet
maybe others.
just one difference will make the MS carb a different part no.
There is an I&T Unit Repair Manual that tells some of this info (Jets and nozzles).Probably other sources. Mine tapers off in the 500-600 range. I'm in college and won't see mine for about 2 weeks.
I Redman
02-21-2001 15:05:42
 Re: Re: MS Carbs On Molines in reply to kelvin, 02-21-2001 12:30:24
Are you talking about a unit repair manual for just MS carbs by I&T????? ????? ???? IF so I didn't know they made such a book. AKA a component maintnance manual, I would like more info whenever you have the ability to pass it on. BIG BIG Thanks.. I Redman
Kelvin
02-22-2001 17:12:53
 Re: Re: Re: MS Carbs On Molines in reply to I Redman, 02-21-2001 15:05:42
Had to call home and get Mom to find it.
It's an I & T "Standard Units Shop manual" SU-2 Has info on carburetors, and I think starters, generators, clutches. I mainly bought it for the Carb. info.
red dog
02-18-2001 06:00:29
tsx-67 U series,tsx-693 5 star,gvi,670.
Jim Parisot
02-17-2001 22:32:03
I.R.
Well, a TSX-67 fit on earlier U's, and I don't know what a TSX-693 fits. Are you trying to figure if they are interchangeable? Know what the 693 fit? Are they the same size venturi and bore? If so they will probably work interchangeably. Be a little more specific, exactly what do you want to know?
Jim
