G 1350 and G1355 push and pull type cluches
M Kuhns
03-10-2001 16:53:52
I have a White 2-150(same as a G1355). I added a turbo to this tractor and I am pushing out about 225 HP. This tractor works well pulling a 28 foot disc on hilly land when weighing about 18,000Lbs. Anyway I can't always hold all that power. My clutch slips. I also have a Oliver 2155(one of about 210 made)(same as G1350 MM). This tractor has a pull type clutch instead of a push type like my 2-150 has. The 2155 we use for pulling all the time pushing out about 350HP(thats right) and the clutch handles it no problem. I was wondering what I would have to change other than the pressure plate and flywheel to convert my 2-150 from a push type clutch to a pull type clutch in my 2155. I was going to use my 2-150 clutch over again since I just put it in new. The 2-150 has and oliver torque and the 2155 has the MM T\A in it. How did moline couple these two different combinations to one engine? I was told the input shaft on the oliver torque was made a little longer to accomadate for the two different clutches. Any information would be helpful.
