1350-1355 pull
push type clutches
M Kuhns
03-11-2001 14:46:57
I have a white 2-150(same as a MM G1355) that I run about 225Hp out of to farm with. It works real well with a 28 foot disc when weighing about 18,000Lbs. I farm real hilly land. When I really work it, the clutch slips. I already added all the extra springs to the pressure plate and i don't have any oil on the clutch. I also have an Oliver 2155 (one of 210 made)(same as a G-1350 MM). I use this one for pulling and run about 350-400Hp and the clutch doesn't ever slip. THe only difference is the 2-150 has a push type clutch and the 2155 has a pull type. I was wondering what I would need to change other than the flywheel and pressure plate to convert to the pull type clutch. The 2155 has a MM T\A and the 2-150 has an Oliver Over\Under. I was told that I might have to change the T\A input shaft on the 2-150. Will the shaft hub that runs the hydraulic pump and PTO still work thatbolt into the flywheel? Any input would be appreciated.
