5 Star Transmission
John Dvorscak
04-10-2001 06:04:27
I am in the process of restoring a 1959 5 Star gas tractor. I just got it running and driving as it had set for at least 5 years. I noticed that when the transmission is in gear and the clutch is disengaged, the tractor does not roll freely and acts like the brake is on. When the trans is in neutral it does roll freely. Is this normal or is there a problem I should be looking into. Otherwise the tractor drives normally. Thank you.
ErnieD
04-23-2001 18:27:48
 Re: 5 Star Transmission in reply to John Dvorscak, 04-10-2001 06:04:27
MM had what my neighbor called hill hold, in gear it would not roll back when the clutch was depressed. It is the way they were built.
Harrold Rhodes
04-14-2001 20:15:31
You will get some drag when your trans is in gear even though you have clutch disengaged due to gears, shafts and bearings turning. As your gear oil warms up this will decrease.
Jeff
04-11-2001 16:53:11
My 5 star is the same way
