MM Hay Rake
Tonya
04-17-2001 08:59:50
I just bought a 5 bar hay rake and it needs alot of work. I can't find a serial number or anything like that on it. Does anyone know where I can parts for it?
Bill Becker
04-18-2001 08:28:52
 Re: MM Hay Rake in reply to Tonya, 04-17-2001 08:59:50
Does your rake have steel wheels? If so, it's probably an OMA rake. Moline made two versions of this rake. One was a straight rake and the other was a rake / tedder. You can tell the difference by looking at the teeth and the drive gears. If the gears are enclosed and the teeth are angled, it is a straight rake. The rake / tedder has open gears and straight teeth. I had two of these rakes that I made one good one out of and have a lot of parts left that I will probably end up scrapping if no one has a use for them.
Chris Sublett
04-17-2001 19:07:11
I bought one about a year ago. Mine is all there with the exception of some teeth. If you figure out were to find them I would like to know. Thanks Chris S.
Tonya
04-18-2001 06:00:10
 Re: Re: MM Hay Rake in reply to Chris Sublett, 04-17-2001 19:07:11
My boyfriend and I are working on get it working. I found the number to a guy in Gnadenhutten, Oh. We are going to go down the first of next week to go through his index books to see what we can find. If we find someplace to get original parts I will let you know. As for now, we went to Farm and Fleet last night, we found some teeth that are rubber at the top. They work perfectly!
