What is the consensus on a UTS? Please tell me high and low points.
Aaron Richter
04-23-2001 18:27:51
I am considering buying a 1948 or 1949 mm UTS. I am a farmall man and have no experience with minnies. I would appreciate any response explaining strengths and weaknesses of the UTS such as turning radius, drawbar power etc.
Thank you,
Aaron
Pete
04-24-2001 20:55:15
 Re: What is the consensus on a UTS? Please tell me high and low points. in reply to Aaron Richter, 04-23-2001 18:27:51
The UTS is similar to the IH W6. Personaly I like the M-M hand clutch better than W6 clutch. On the H & M's the foot clutch is nice but on the IH wheatlands the clutch pedal is higher to operate. When you use the M-M hand clutch you can make the tractor creep along which is nice when hitching to implements. M-M's hand clutch is smother that the green and yellow tractors are. As with any new tractor it will take time to get a feel for how it operates. The wider steering of a standard tread tractor takes some geting use to.
Kelvin
04-24-2001 15:50:58
I have 3 UTS. 2 1949 and 1 1954. Don't expect a great turning radius. Not nimble. The biggest drawback I feel is the seat. Its too low. if you're short you have to look to one side or the other of the hood.
They seem to have been good, strong and extremely long lasting tractors. The hood side will probably be rusted out around the exhaust pipe-to be expected. If you're a farmall man, you'll have to get used to the hand clutch. Just don't get in a hurry. The U series is one of the longest production tractors Moline made.
