MM 284 and 400 motors
David
11-15-1998 11:31:52
I am interested in knowing if the "top"end of the 283-4 and the 400-A motors are interchangable. ie. could one swap the connecting rod or swap the crank up between these engines?
Can cracked heads be repaired (283-A)?
Can cracked cylinders be repaired (283)?
Will the 400 and the 283 PTO on the free standing power supply motors interchange?
Can a 400 free standing power supply motor be bolted up to a U tractor?
I could go on for ever, but I'll stop here for now.
Thanks for any help, DGW.
mm
11-15-1998 16:02:05
 Re: MM 284 and 400 motors in reply to David, 11-15-1998 11:31:52
We've beat this to death previously. Check about 2/3 to 3/4 the way down this discussion board. Your on the right track. The 403 just isn't big enough anymore. These guys are talking 600-750" engines now. : I am interested in knowing if the "top"end of the 283-4 and the 400-A motors are interchangable. ie. could one swap the connecting rod or swap the crank up between these engines?
: Can cracked heads be repaired (283-A)?
: Can cracked cylinders be repaired (283)?
: Will the 400 and the 283 PTO on the free standing power supply motors interchange?
: Can a 400 free standing power supply motor be bolted up to a U tractor?
: I could go on for ever, but I'll stop here for now.
: Thanks for any help, DGW.
