Jetstar 3 Super PTO
Jack
05-01-2001 18:03:19
I have just reassembled a Jetstar 3 Super PTO unit that had been left in a basket case state. I have not yet run the engine since the PTO unit and hydraulic pump are installed. At the rear of the PTO powershaft are two small bearings which have an oil drain hole above them. It appears that gear oil which splashes up against the top cover of the housing is supposed to drain through the hole and lubricate the bearings. However, with the recommended 10 gallons of gear oil in the case, the lubricant does not come up to the level of the PTO clutch unit, which rotates with the powershaft when the tractor runs. If the tractor is moving, the bull gears will throw oil up against the cover and lube the bearings. But if the tractor is not moving, how do the bearings get lubricated? Should the oil level in the case be high enough so that the PTO clutch unit constantly slings oil into the drain hole?
