1953-55? ford tractor 600
640 wiring diagram
Robert Peternel
05-01-2001 20:40:39
I just purchased the tractor and the regulator would only charge when I pushed the relays in on the regulator.I then noticed that the 6-volt battery was at negative ground. It has all original parts ( generator, starter etc.) but the regulator has been changed and the coil wires reversed. It was actually charging in reverse. I have reverse the polarity on the generator and switched the battery poles, It will run for a few minutes(not charging) then cut out. I am going to try tommorrow to reverse the coil wires also but that won't help the charging system any. I can not find on the net a wiring diagram anywhere for this tractor and the vintage tractor site diagram is down.I am dumfounded and tired and should of payed more attention to my Father's electrical training as a boy. Please help. Thank you Robert M Peternell ps: Trator was sold to me as a 53 but other sites say different, I believe 1955.
Al Holmes
06-22-2007 14:12:09
 Re: 1953-55? ford tractor 600 - 640 wiring diagram in reply to Robert Peternell, 05-01-2001 20:40:39
I have a Ford 600 1953, [I think]. It has been switched to a 12 V system. The wiring [except plug wires are off and I have no idea what wire goes where. Where can I find diagram? Could you sketch or send one>
Thanks ,
Al
Steve Roth
09-02-2007 07:41:54
 Re: 1953-55? ford tractor 600 - 640 wiring diagram in reply to Al Holmes, 06-22-2007 14:12:09
Please help
Garry Brashear
10-12-2006 17:03:47
the wiring on my 53 ford tractor is a real mess it has 12v battery and alternator it has a resistor in line with the coil. When i turn off the ignition. the engine won't stop unless i disconnect the field wire to alternator. please help.I need a wiring diagram.
Paul Jennings
01-03-2004 17:02:50
Robert, Follow up on my last responce to your search for a wiring diagram for your Ford tractor. Go to ( Nseries.com ) web site. Under Maintenance click on wiring diagrams, then scroll down to the bottom of the page and there is a wiring diagram for a NAA/Golden Jubilee tractor. My 600 is the same only two years newer. Paul Jennings
Paul Jennings
01-03-2004 16:34:19
Robert, I own a 1955 Ford 600 series tractor. If your tractor is a 1953 it is the first of the 600 series tractors and will have a large nut on the outside of the rear axle to hold the rear hub on and the lug bolts will be in the hub. As far as I know, it was the only year of the 600 series that had that type of rear axle, but please don't quote me on that. All the rest of the 600s had a flanged axle with the lug bolts in the axle flange. My tractor was converted to 12 volts years ago and as I am restoring it to original, I'm converting it back to 6 volts. I don't have a wiring diagram for it yet. As to your problem, Ford had a habit back in the 40s and 50s of using a positive ground on all of their cars and trucks. That tells me that it is very possible that their tractors used the same system. If you ever find out where a wiring diagram can be had, I sure would like to know. If I find one, I'll Let you know. Let's keep the Fords rolling.
Paul Jennings, Loris,SC
Stephen Koch
07-02-2004 19:41:30
 Re: Re: 1953-55? ford tractor 600 - 640 wiring dia in reply to Paul Jennings, 01-03-2004 16:34:19
Love to recieve your shared info. Will also contribute when possible.
