445Moline Crankshaft
ANTKLE
05-06-2001 07:22:41
My 445 Spun a rear main bearing ,crank is bad .Am wondering if any other MM`s are interchangeable--ie the R series ,the Z, Jet Star---Others??
Thanks, Tom
River Dale Farms
05-06-2001 18:51:26
 Re: 445Moline Crankshaft in reply to ANTKLE, 05-06-2001 07:22:41
If you need a crankshaft let us know, have several on the shelf, Dale
Harrold Rhodes
05-06-2001 12:14:28
The Jet and 4star had basicaly same engine. The 335 was smaller cid but I think crank was same. 302 was larger CID but again I think crank was same. The 206 was also used in some industrials and forklifts.
Harrold Rhodes
05-08-2001 19:02:55
 Re: Re: 445Moline Crankshaft in reply to Harrold Rhodes, 05-06-2001 12:14:28
Just a case of the old memory getting fuzzy. I can add that to the long list of things I've been wrong about. I guess it's the bore not the stroke that's the same on 335 and 445
Keith Peterman
05-08-2001 12:55:18
335 crank is not the same as a 445/4 Star crank. The 335 is a 4" stoke crank. The 445/4 Star is a 5" stroke.
