MM 445 starter/ring gear problems
Mark
05-30-2001 15:24:11
Looking to buy a 445 with HD loader and backhoe. Starter does not always lock up with ring gear. Owner thinks ring gear is worn but tells me that the problem goes away for a few years after replacing starter drive. I looked at old starter and gear teeth were worn on leading edge as if wasn't throwing into ring gear far enough. Can anyone offer opinions on this? I would not be anxious to replace ring gear. Owner is asking $3500 for unit...does this sound fair? Thank you. Mark
Kimberly Thompson
06-05-2001 16:17:58
 Re: MM 445 starter/ring gear problems in reply to Mark, 05-30-2001 15:24:11
My dad has a '47 Minneapolis Moline that needs a starter. Anyone know where I can find one for him? I'd like to get it for him for Father's Day. If not, he wants to sell it. Anyone interested?
Rick
06-01-2001 16:48:27
Sounds like to me you are buying $3500.00 worth of trouble. To turn the ring gear, what you are not being told is that you will be required to split the tractor and remove the flywheel to do this.
That is only if you don`t have trouble after you put it all back togetter.
R M in Ont
05-30-2001 19:37:00
Starter drive gears are normally made with the rounded leading edge. More than likely the ring gear has areas that the teeth are worn. The ring gear can be heated and turned 90 degrees on the flywheel to give the starter gear a better place to catch. The ring gear can be removed and turned backwards.
People told me it couldn't be done that way, that
the starter would never engage because the ring gear teeth were chamfered the wrong way. Well I got news for those guys, it can be done and my starter engages just like a brand new one.
jakob
05-30-2001 19:19:14
I don't know if this could be it, but maybe it has the wrong starter. Also make sure that the starter is aligned into the flywheel housing correctly.
