For sale: M-5 and UB puller
Keith
11-19-1998 17:53:10
I have a M-5 with 300 dual loader, no three point and the tractor has worked all it's life but runs when needed and the torque still functions
I also have a UB puller for sale. It is 4.81 X 6.18 (449cu.in) The heads are 4210 flowed with a ground cam and big carb. It has good paint with mm red flames. Tires are 16.9 x 38's on 18 inch rims. It has electronic ignition and other extras. price for m-5 is 2000 and 4250 for
the UB. (712) 4776-5315
Brian Rukes
11-20-1998 11:19:47
 Re: For sale: M-5 and UB puller in reply to Keith, 11-19-1998 17:53:10
Where are you located? I might be interested in the M-5.
Thanks,
Brian Rukes
The M-M Registry
: I have a M-5 with 300 dual loader, no three point and the tractor has worked all it's life but runs when needed and the torque still functions
: I also have a UB puller for sale. It is 4.81 X 6.18 (449cu.in) The heads are 4210 flowed with a ground cam and big carb. It has good paint : with mm red flames. Tires are 16.9 x 38's on 18 inch rims. It has electronic ignition and other extras. price for m-5 is 2000 and 4250 for
: the UB. (712) 4776-5315
Keith
11-21-1998 09:13:46
 Re: Re: For sale: M-5 and UB puller in reply to Brian Rukes, 11-20-1998 11:19:47
: Where are you located? I might be interested in the M-5.
: Thanks,
: Brian Rukes
: The M-M Registry
: M-5 sold 11-20-98
: : I have a M-5 with 300 dual loader, no three point and the tractor has worked all it's life but runs when needed and the torque still functions
: : I also have a UB puller for sale. It is 4.81 X 6.18 (449cu.in) The heads are 4210 flowed with a ground cam and big carb. It has good paint : : with mm red flames. Tires are 16.9 x 38's on 18 inch rims. It has electronic ignition and other extras. price for m-5 is 2000 and 4250 for
: : the UB. (712) 4776-5315
big d
11-26-1998 17:15:22
 Re: Re: Re: For sale: M-5 and UB puller in reply to Keith, 11-21-1998 09:13:46
: : Where are you located? I might be interested in the M-5.
: : Thanks,
: : Brian Rukes
: : The M-M Registry
: : M-5 sold 11-20-98
: : : I have a M-5 with 300 dual loader, no three point and the tractor has worked all it's life but runs when needed and the torque still functions
: : : I also have a UB puller for sale. It is 4.81 X 6.18 (449cu.in) The heads are 4210 flowed with a ground cam and big carb. It has good paint : : : with mm red flames. Tires are 16.9 x 38's on 18 inch rims. It has electronic ignition and other extras. price for m-5 is 2000 and 4250 for
: : : the UB. (712) 4776-5315
Jeez -- your not serious about selling the UB are
you?
